ouragan66
SD Card Formatter...
ouragan66
Programma da utilizzare obbligatoriamente per formattare SD card ( SD/SDHC/SDXC )...
io non lo sapevo...
SD Card Formatter 4.0 for SD/SDHC/SDXC
This software formats all SD memory cards, SDHC memory cards and SDXC memory cards. SD Card Formatter provides quick and easy access to the full capabilities of your SD, SDHC and SDXC memory cards.
The SD Card Formatter was created specifically for memory cards using the SD/SDHC/SDXC standards. It is strongly recommended to use the SD Card Formatter instead of formatting utilities provided with operating systems that format various types of storage media. Using generic formatting utilities may result in less than optimal performance for your memory cards.
The SD/SDHC/SDXC memory cards have a "Protected Area" on the card for the SD standard's security function. The SD The SD Card Formatter does not format the "Protected Area". Please use appropriate application software or SD-compatible device that provides SD security function to format the "Protected Area" in the memory card.
ouragan66
ouragan66
SD Speed Class/UHS Speed Class/Video Speed Class
Greater Performance Choices
There are three kinds of Speed Classes, "Speed Class", "UHS Speed Class" and "Video Speed Class."
As a characteristic of flash memory, actual transfer speed varies. Variable speeds are difficult to reliably record streaming content such as video because it requires a constant writing speed. Speed Class and UHS Speed Class provide the constant speed necessary for video recording by designating a minimum writing performance so that minimum and constant speed could be achieved for camcorders, video recorders and other devices with video recording capabilities under the conditional write operation specified in the standard.
  • Speed Class is marked  with Class 2, 4, 6 and 10 (DS, HS mode), UHS Speed Classes is marked with U1 and U3 (UHS mode), Video Speed Class is marked with V6,V10,V30,V60,V90 (HS, UHS mode).
  • The latest Video Speed Class covers conventional Speed Class and UHS Speed Class and designed to optimize modern NAND memory technology for high resolution & High quality video and multi-file Recording.
  • Speed Class, UHS Speed Class and Video Speed Class has no compatibility
ouragan66
SD Memory Card Choices
What Card Works Best with Your Device?
Hundreds of manufacturers have built thousands of memory cards and devices to SD standards. Memory cards come in a variety of storage capacities, speed classes and three different physical sizes -- SD memory card, miniSD memory card, and microSD memory card. With so many choices, it’s important to understand which SD memory card works best with your mobile phones, tablets, personal computers, video cameras, digital cameras and other electronics devices.
There are three important standards to choose best SD card for your devices.
1.Speed Class Standards for Video Recording
Go to the page
Speed Class regulate minimum write performance required for video recording.
2.Bus IF Speed Standards for Large Size Data Transfer
Go to the page
Bus IF Speed regulate performance for high-speed writing and reading to and from SD card.
3.File System for Data Storage Capacity
Go to the page
File System support various file formatted data for host devices.
https://www.sdcard.org/downloads/formatter_4/index.html
    282.643
    5.886.444
