Help scelta cavi di potenza Cardas
4 ore fa, zagor333 ha scritto:
Ho trovato una foto in rete dei Cygnus biwiring, in effetti anche per questo modello i cavi hanno sezioni diverse per bassi e alti.
Roberto
Sia dal sito che nel listino i cavi sono uguali, 4 x 15 AWG:
https://www.cardas.com/clear-cygnus
It wasn’t easy to improve upon Clear Light without giving up it’s incredible value, but we did it! Clear Cygnus is more revealing, more holographic, and more refined. Matched Propagation conductors help to provide a very open and dynamic sound. In addition it can be internally bi-wired which wasn’t an option with Clear Light.
Standard Terminations: Cardas spades or bananas forged using 10,000psi
Design/Construction: Conductors: Braided Matched Propagation Kevlar core, Grade 1, 99.9999% pure OFHC copper with SPN clear coat (Litz), gauge sizes scaled to Golden Ratio proportions. Cross-field layer geometry, insulated in a PTFE tape and Electro-Dissipative dielectric.
Geometry: Concentrically braided four conductor surrounded by anti-static fibrillated polypropylene fibers. Outside jacket is a soft and flexible TPE rubber.
Gauge: 4x15 AWG
Outside Diameter: 0.695”/17.67mm
See how we perform Cygnus Speaker Cable's solder-less forged terminations:
https://melius.club/topic/25858-help-scelta-cavi-di-potenza-cardas/page/2/#findComment-1547998
5 ore fa, Pink ha scritto:
nei clear reflection le sezioni sono differenti
Dove hai letto che le sezione sono differenti?
Sia sul sito che nel listino affermano che sono 12 x 11,5 AWG, quindi tutti stesse dimensioni, c'è anche l'immagine, i cavi se non ho preso un abbaglio, dovrebbero essere tutti uguali:
https://www.cardas.com/clear-reflection
Designed to blend the best of Golden Reference with the benefits of Clear and Matched Propagation technology. This cable has the richness and musicality of the classic and very successful Golden Reference, but also has the clarity and transparency of Clear. It can be internally bi-wired or tri-wired.
Design/Construction: Matched Propagation Conductors, Kevlar core Grade 1, 99.9999% pure oxygen free copper with SPN clear coat (Litz), gauge sizes scaled to Golden Ratio proportions. Cross-field layer geometry, insulated in a FEP taped jacket.
Geometry: Anti-static fiber core Tri-Quad 12 conductor with anti-static filler to separate the three groups bound together in FEP tape. Flexible TPR outer jacket.
Gauge: 12x11.5 AWG
Outside Diameter: 0.680”/17.27mm
See how we perform Clear Reflection Speaker Cable's solder-less forged terminations:
https://melius.club/topic/25858-help-scelta-cavi-di-potenza-cardas/page/2/#findComment-1547999
9 ore fa, goldeye ha scritto:
Anni fa' contattai direttamente la Cardas per informazioni riguardo i vecchi Hexlink Golden 5 C ,mi hanno risposto subito, ammettendo che la versione biwire era lo stesso cavo con connettori doppi lato diffusori.
Spero che nei nuovi modelli,sia differente 😉
Il cavo è sempre quello, non è che la versione biwire è diversa in casa Cardas, però ogni modello può cambiare, ad esempio i miei Clear Light non possono essere biwire perchè hanno solo 2 conduttori, a me va bene, perchè le Focal Sopra 2 hanno un morsetto unico, mentre parecchi modelli nel catalogo hanno 4 conduttori, alcuni 8 e alcuni neanche ricordavo addirittura 12 come il Golden Reflection, quindi è possibile terminarli in versione biwire.
Anche per gli altri marchi è così, non è che fanno una versione monowire e una biwire, quella biwire se hanno progettato il cavo per questa possibilità è perchè dentro ci sono almeno 4 conduttori.
Poi recentemente Audioquest ha sviluppato dei cavi separati, ma non credo che ne esisteranno molti di costruttori con questa politica, Audioquest stessa in passato dava la doppia possibilità di terminazione su tutti i cavi in catalogo, ma il cavo sempre quello era, anche tutt'ora se prendi le serie diciamo basse tipo Rocket puoi scegliere come terminarlo, ma nella versione biwire sdoppiano solo l'uscita essendo formati da 4 conduttori interni, nuila di nuovo sotto il sole e lo fanno quasi tutti.
Comunque non è una soluzione scarsa, perchè già che togli il ponticello di serie comunque è già una buona soluzione, poi se si ha la pecunia e si vuole un po' strafare si comprano 2 cavi mono, ma onestamente si può fare con cavi poco costosi, ma a quel punto il risultato resta quello che è, se metti doppia mandata di cavo scarso.
Va benissimo sdoppiare il cavo buono o usare un ottimo ponticello con cavo monowire, non cambia molto.
https://melius.club/topic/25858-help-scelta-cavi-di-potenza-cardas/page/2/#findComment-1548001
@PietroPDP Quotone...
Con le Proac Response 3.8 avevo un vero cavo biwire ( 2 modelli diversi sotto la stessa "pelle") addirittura con connettori diversi lato diffusori.
Attualmente uso un cavo monowire,ma con un ottimo jumper 😉 và bene così!
https://melius.club/topic/25858-help-scelta-cavi-di-potenza-cardas/page/2/#findComment-1548055
58 minuti fa, Pink ha scritto:
@PietroPDP intendevo che nel cavo terminato biwiring , sono diverse le sezioni per alti e bassi però utilizzando sempre lo stesso cavo
@PietroPDP
Probabilmente avendo 12 conduttori la gamma bassa forse ne avrà 8?
Non saprei in questo caso.
https://melius.club/topic/25858-help-scelta-cavi-di-potenza-cardas/page/2/#findComment-1548298
  • 2 mesi dopo...
@Aldo Maietta niente è scritto, devi provarli. Sono dei top di casa Cardas, ma questo non ti garantisce che vadano obbligatoriamente bene sul tuo sistema.
Se hai modo, fattelo prestare e se vanno bene li tienti.
Diversamente, sono un acquisto alla cieca e l'importo non è da poco.
https://melius.club/topic/25858-help-scelta-cavi-di-potenza-cardas/page/2/#findComment-1607502
@zagor333 Io ho i Cygnus, con le Cornwall 4 che sai bene essere taglienti in alto, con la tromba, beh il suono è molto equilibrato con i Cygnus e non è mai affaticante, con un diffusore del genere emergerebbe subito un eventuale asprezza....Non sbagli di sicuro, comunque con le SF difficile che un cavo riesca a farle suonare frizzanti....forse un Nordost... considera poi la sinergia con cavo segnale e alimentazione, il cavo bilanciato fa molto del suono.
https://melius.club/topic/25858-help-scelta-cavi-di-potenza-cardas/page/2/#findComment-1607689
17 ore fa, Aldo Maietta ha scritto:
Signori scusate cosa ne pensate di questo cavo per collegare il Mc Intosh Mc 462 a una coppia dí Sonus Faber Serafino?
CARDAS AUDIO CLEAR REV1 2,5 MT SPADE
Come dice Nino vanno sempre provati, ma sarò di parte non dovresti trovarti male, solitamente vanno bene su molti sistemi, perchè per un periodo vari Cardas li avevamo su molti sistemi anche di amici e svolto varie prove, ora alcuni sono possati ad altro marchio, io sono rimasto con Cardas, mi trovo bene, i miglioramenti di lato e costosi non mi hanno mai entusiasmato.
Almeno come li reputo io per i miei canoni, i miei amici sono super soddisfatti.
https://melius.club/topic/25858-help-scelta-cavi-di-potenza-cardas/page/2/#findComment-1608151
