GuidoR Inviato 11 Settembre 2025 Condividi Inviato 11 Settembre 2025 Ho visto degli "spinotti" di nordost che promettono miglioramenti nella linea. in sostanza anzichè utilizzare una multipresa filtrata, uno inserisce nella sua multipresa uno o più di questi spinotti e dovrebbero migliorare l'alimentazione elettrica dell'impianto, con ricadute positive sul suono. qualcuno li ha provati? https://www.nordost.com/qrt/plugins.php Nordost’s QRT AC Enhancers and AC Line Harmonizers are a range of modular, complimentary AC products which improve upon the poor-quality AC that negatively affects the audio/video performance of two-channel and home entertainment systems. Despite their overarching synergy, each Nordost plug-in can be used as a stand-alone product, providing its own, unique solution to the “AC problem”. Nordost's AC Enhancers, the QKOIL and the QSINE, are both passive field generators. While the QKOIL generates a field created by its Micro Mono-Filament-made Load Resonating Coil (LRC), the QSINE reshapes the sine wave by introducing specific frequency fields onto the circuit path which, in turn, lowers the effects of EMI noise embedded into the AC power. Nordost's AC Line Harmonizers, the QVIBE and the QWAVE, on the other hand, are active devices. They each introduce their own carefully calculated ranges of pulsed frequencies, clocked from the original 50 or 60Hz waveform, directly onto the AC line. This manipulation of the AC signal allows these products to better control the harmonics and overtones attributed to many improvements, not least of which is the enhanced realism of both the musical and visual aspects of performance. While the effects of Nordost's QRT plug-ins are clearly apparent when used individually, the benefits of the QVIBE, QKOIL, QSINE, and QWAVE are cumulative and are best enjoyed when integrated into a full suite of QRT products. Once integrated into a hi-fi system, listeners will notice: • A reduction of EMI on the AC line • A lower noise floor • An increase in the clarity, detail, and pacing of musical reproduction • Increased imagery and dimensionality of the soundstage • Greater musicality and improved tonal balance • A deeper, more dimensional and vibrant picture on AV Systems Link al commento https://melius.club/topic/26465-nordost-qrt-qualcuno-li-ha-provati/ Condividi su altri siti Altre opzioni di condivisione...
newton Inviato 13 Settembre 2025 Condividi Inviato 13 Settembre 2025 Avuti anni fa (si chiamavano in modo un po' diverso) e rivenduti dopo esser passato a PS Audio senza rimpianto alcuno. Qualcosa fanno, il rapporto qualità prezzo non è il massimo secondo me: alle fiere tappano tutti buchi non utilizzati delle multiprese nordost. Essendo filtri in parallelo non hanno problemi di dinamica ma appunto ce ne vogliono molti e non li regalano. Link al commento https://melius.club/topic/26465-nordost-qrt-qualcuno-li-ha-provati/#findComment-1588538 Condividi su altri siti Altre opzioni di condivisione...
GuidoR Inviato 15 Settembre 2025 Autore Condividi Inviato 15 Settembre 2025 @newton grazie mille. PS Audio è ad alto livello Link al commento https://melius.club/topic/26465-nordost-qrt-qualcuno-li-ha-provati/#findComment-1590138 Condividi su altri siti Altre opzioni di condivisione...
newton Inviato 15 Settembre 2025 Condividi Inviato 15 Settembre 2025 @GuidoR Prego. Anche Nordost è roba di livello e hanno una loro filosofia sull'alimentazione. Ripeto, qualcosa fanno: certo se uno inizia a comprare la multipresa, questi spinotti, l'aggeggio per la terra, va su cifre con le quali si aprono scenari anche diversi. Link al commento https://melius.club/topic/26465-nordost-qrt-qualcuno-li-ha-provati/#findComment-1590286 Condividi su altri siti Altre opzioni di condivisione...
rpezzane Inviato 19 Settembre 2025 Condividi Inviato 19 Settembre 2025 @GuidoR io li ascoltai in una fiera in cui c’era proprio Nordost a presentare sia questi armonizzatori che la ground station. Gli armonizzatori non mi piacquero e glielo dissi pure al tizio perché rendevano il suono un po’ artificioso e poco naturale. Molto valida invece la ground box. Saluti Link al commento https://melius.club/topic/26465-nordost-qrt-qualcuno-li-ha-provati/#findComment-1593482 Condividi su altri siti Altre opzioni di condivisione...
gian62xx Inviato 19 Settembre 2025 Condividi Inviato 19 Settembre 2025 Me ne ha prestati un paio (2 modelli diversi) il mio fornitore, provati e riprovati. Effetto zero. Link al commento https://melius.club/topic/26465-nordost-qrt-qualcuno-li-ha-provati/#findComment-1593531 Condividi su altri siti Altre opzioni di condivisione...
godzilla Inviato 19 Settembre 2025 Condividi Inviato 19 Settembre 2025 io uso quelli della Ifi, costano molto meno e si sentono chiaramente. Massimo 1 Link al commento https://melius.club/topic/26465-nordost-qrt-qualcuno-li-ha-provati/#findComment-1593558 Condividi su altri siti Altre opzioni di condivisione...
danielet80 Inviato 19 Settembre 2025 Condividi Inviato 19 Settembre 2025 Vedo che spesso sono in vendita su Subito, penso quindi non sortiscano gran effetto sulla riproduzione. Nel mio impianto uso il PS Audio P15 e mi trovo molto bene. Link al commento https://melius.club/topic/26465-nordost-qrt-qualcuno-li-ha-provati/#findComment-1593840 Condividi su altri siti Altre opzioni di condivisione...
GuidoR Inviato 19 Settembre 2025 Autore Condividi Inviato 19 Settembre 2025 @godzilla che modelli della ifi? @danielet80 ps audio é una certezza. Secondo te modifica il suono? Link al commento https://melius.club/topic/26465-nordost-qrt-qualcuno-li-ha-provati/#findComment-1593869 Condividi su altri siti Altre opzioni di condivisione...
GuidoR Inviato 19 Settembre 2025 Autore Condividi Inviato 19 Settembre 2025 @gian62xx grazie Gian Link al commento https://melius.club/topic/26465-nordost-qrt-qualcuno-li-ha-provati/#findComment-1593870 Condividi su altri siti Altre opzioni di condivisione...
danielet80 Inviato 20 Settembre 2025 Condividi Inviato 20 Settembre 2025 @GuidoR Una volta inserito nell'impianto ho notato più chiarezza, più apertura e più silenzio di fondo, quindi più che modificare il suono in se, ti direi che migliora i parametri di ascolto. Poi ho acquistato pre e ampli Accuphase e li ho utilizzati con e senza PS Audio e se devo essere onesto, un miglioramento c'è stato ma molto limitato in quanto le elettroniche Accuphase, specialmente gli alimentatori, sono isolati e sono molto molto silenziosi che neppure ci si accorge di averli accesi. Penso che PS Audio intervenga favorevolmente nell'impianto ma ci sia una stretta correlazione con le elettroniche in uso. Ci sono anche utenti che l'hanno venduto dopo poco perchè dicono che il PS Audio limita la dinamica: può essere, secondo me dipende sempre dalle elettroniche che vengono collegate. Link al commento https://melius.club/topic/26465-nordost-qrt-qualcuno-li-ha-provati/#findComment-1594745 Condividi su altri siti Altre opzioni di condivisione...
godzilla Inviato 21 Settembre 2025 Condividi Inviato 21 Settembre 2025 @GuidoR questo, il suppostone.. https://www.amazon.it/iFi-Audio-AC-iPurifier/dp/B0CDC6TYCD/ref=sr_1_25?crid=1BE9AWJMV73S3&dib=eyJ2IjoiMSJ9.zHf_rrut6vnQmWCqR2QqVbRt5eClBftheTIPyF2-TDGPDAZgcEy1EV10yZ7mIDYKsiqs9yViOup7j7uqmmXwu9duCopvDErWdTwvhBakB1KbUmkJfK8COXw3Hh3_m6XOz0I-1J_gYWHa9-jMKSuUAWj8oap60oh-xlbcYTNIAbEMH1QABV9RmdhkJa9l-tcnDG0emNBt_LvdTgdg4p2mJJiGz-T7CCXP6OOzjlgtLoXNYuve0rAadpXw_jCWvABYt692Qt4ysq7xrLMJhk1XywlVmq0v4mgI1YoxRDNXS0w.ed2CcL6M5Xc2wj4dNMn1zQxNtBa-gc3rf5ewuRrxlMU&dib_tag=se&keywords=ifi+audio&qid=1758453807&s=electronics&sprefix=ifi%2Celectronics%2C90&sr=1-25&ufe=app_do%3Aamzn1.fos.4ed3ebda-5e83-4808-af48-7e08fa6b1d8b&xpid=ayEzIFuTYXI1G Link al commento https://melius.club/topic/26465-nordost-qrt-qualcuno-li-ha-provati/#findComment-1595085 Condividi su altri siti Altre opzioni di condivisione...
GuidoR Inviato 22 Settembre 2025 Autore Condividi Inviato 22 Settembre 2025 @danielet80 alcuni consigliano di collegare le sorgenti ma non le amplificazioni effettivamente. io ho elettroniche naim e loro sconsigliano ogni tipo di filtro, però ho dovuto mettere un dc blocker perchè tutte le elettroniche emettevano un hum fastidioso Link al commento https://melius.club/topic/26465-nordost-qrt-qualcuno-li-ha-provati/#findComment-1595906 Condividi su altri siti Altre opzioni di condivisione...
GuidoR Inviato 22 Settembre 2025 Autore Condividi Inviato 22 Settembre 2025 @godzilla grazie mille, interessante. che miglioramenti hai notato? qualcun altro l'ha provato? Link al commento https://melius.club/topic/26465-nordost-qrt-qualcuno-li-ha-provati/#findComment-1595908 Condividi su altri siti Altre opzioni di condivisione...
godzilla Inviato 22 Settembre 2025 Condividi Inviato 22 Settembre 2025 @GuidoRè un necessorio, per me, fa molto, per essere un accessorio.. Massimo Link al commento https://melius.club/topic/26465-nordost-qrt-qualcuno-li-ha-provati/#findComment-1596041 Condividi su altri siti Altre opzioni di condivisione...
