Radio paradise .flac per LUMIN!
Allego il "messaggio" di LUMIN, se potesse servirVi.
Buoni ascolti.
Lumin Radio Paradise and other radio FLAC
Hi,
Here's a beta firmware for Radio Paradise FLAC and many other FLAC radio for Lumin T2 / X1 / U1(MINI).
Please download this firmware to a USB thumb drive in FAT32 format:
https://www.luminmusic.com/tmp/lumin...8_142beta.upgs
Remove all USB devices from the Lumin. Plug the USB thumb drive into the Lumin. Watch the front panel for upgrade. After a few minutes, it should reboot itself. Then please remove the USB thumb drive and delete the file.
If you are using an external USB DAC, please power cycle the DAC and reconnect it to the Lumin.
Please do not share the file to public.
You'll find many Radio FLAC stations in the radio tab in Lumin app.
Best regards,
Peter
Peter Lie
LUMIN Firmware Lead
https://melius.club/topic/3810-radio-paradise-flac-per-lumin/
