PCM 1704
Lepidus
  • 1 mese dopo...
@Lepidus Many people do not know that the PCM1704 is classified into different categories of perfection. There is the PCM1704U, which is the least expensive and worst lot. Then there are better ones, which are marked PCM1704U-J and PCM1704U-K at the factory. We would like to stress that the LessLoss DAC 2004 uses only the best and most expensive PCM1704’s. We have chosen the best converter and then use only the best lot of these converters.
non so dirti dove trovarli perchè mi risulta siano usciti di produzione, se li trovi vedi la sigla come descritto sopra
https://melius.club/topic/11905-pcm-1704/#findComment-740920
