....a proposito dell'usura testine
...ho letto in questi giorni un report molto interessante sulle testine di Mike Bondell del 2019 ... ne riporto qui un passaggio molto interessante soprattutto per chi ha intenzione di acquisire testine usate (cosa che feci anch'io a suo tempo).
"The maximum number of play hours for advanced stylus shapes that most folks suggest from my reading of dozens of audio forums and many on-line resources is approximately 500 hours on the conservative side and 800 to 1,000 hours on the aggressive side. These non-scientific estimates are significantly lower than the 1,500 to 3,000 plus hours touted for advanced stylus shapes, even among current prominent cartridge manufacturers. Ortofon, for example, publishes on their website that the maximum life for their Shibata-tipped stylus is 2,000 hours. I called Ortofon who cautioned me that by 1,000 hours the cartridge should be examined. Clearaudio recommends in their owner’s manual checking the stylus tip for wear at 500 hours. They also write that the stylus should be replaced after approximately 2,000 hours of use, or sooner if excessive wear and tear is suspected. Audio Technica recommends for their micro line tipped cartridges replacement at 1,000 hours. Nagaoka, a well-regarded Japanese cartridge and stylus tip manufacturer is blunt on its elliptical and line contact options, “…for general use at home, the reference time is between 150-200 hours in which the stylus begin to wear and the tone quality deteriorates. Recommend replacing the stylus as early as possible to enjoy clear tone…and not to damage the disc grooves.” Other well-known manufacturers make no mention of stylus life for their cartridges on their websites and even in user manuals I surveyed."
https://melius.club/topic/876-a-proposito-dellusura-testine/
Ciao Armando,
molto interessante davvero! Sopratutto notavo, le grandi differenze tra i vari marchi.
Ma, io mi chiedo una cosa, negli ultimi 15 anni in casa viaggiano dalle 8 alle 10 testine, molte acquistate nuove o con stilo nuovo.
Ora, posto che ascolto CD, SACD, musica liquida e le testine vanno a rotazione, direi che, almeno nel mio caso e praticamente impossibile tenere il conto delle ore di funzionamento
https://melius.club/topic/876-a-proposito-dellusura-testine/#findComment-24556
Si Francesco l’articolo poi è molto più lungo e molto esaustivo sull’ argomento .... comunque avendo a disposizione un microscopio Shure con 200 ingrandimenti mi sono passato in rassegna  alcune testine con qualche anno ... mah che dire......   diverse sono alla fine;  hanno fatto, come si dice, il giro di “ boa” presentando problemi di usura che possono rovinare  (compromettere secondo l’articolo )il supporto vinilico. La Shure dice ,nell’ articolo, che comunque lo stilo dopo  circa 600... 800 ore di qualsiasi forma  ha perso le sue caratteristiche. Spesso i più analizzano lo stilo con “ lentine” o microscopi digitali “Cinesi” che alla fine servono poco.
https://melius.club/topic/876-a-proposito-dellusura-testine/#findComment-24613
Dipende molto dal materiale della puntina,diamante,corindone ( diamante sintetico ),zaffiro.
Considerando il costo attuale dei diamanti e della loro lavorazione,i costi effettivi attuali delle testine e l'incidenza dei costo del marketing,è necessario salire molto di prezzo per avere una testina con puntina in diamante.
Ci vorrebbe comunque una prova documentata ( come faceva Suono oltre 40 anni fa ).
Con testina nuova e ingrandimento del puntina,dopo 500,1000,2000,5000 ore.
Permettetemi di dubitare degli articoli non documentati.
Le opininioni lasciano il tempo che trovano.
https://melius.club/topic/876-a-proposito-dellusura-testine/#findComment-24719
12 ore fa, bear_1 ha scritto:
...e questo è uno dei link....https://babel.hathitrust.org/cgi/pt?id=mdp.39015017575856;view=1up;seq=5  da leggere dall'inizio alla fine
Ma è uno studio del 1954, cita il peso di lettura di 6-8g.... Per quelle che chiama moderne testine di alta qualità 🤔
  • Haha 2
https://melius.club/topic/876-a-proposito-dellusura-testine/#findComment-25149
Io ho una Goldring dal 1982, usata parecchio, unica testina.
Messa in panchina 4 anni fa: l'ho portata da Torlai per vedere se era da revisionare e com'era messa, dopo averla visionata mi ha detto che era ancora perfetta....
Non so quante ore abbia fatto, bisognerebbe attivare un contatore ad ogni ascolto😅
https://melius.club/topic/876-a-proposito-dellusura-testine/#findComment-25212
