Un impianto di riproduzione audio "ben attrezzato" può riprodurre verosimilmente un evento confinato ad un pianoforte?
What's less understood:
Mid-level processing:
The "middle stages" of auditory processing, between initial transduction in the cochlea and perceptual decisions, are complex and not fully mapped out.
Sound texture perception:
How the brain integrates information from various auditory streams to perceive complex sound textures (like the sound of rustling leaves or a crowd) is still an active area of research.
Auditory-visual interactions:
While some studies suggest that the brain can compare auditory and visual information even when one is presented subliminally, the extent and nature of these interactions are still being explored.
Distance perception:
Humans are less accurate at judging the distance of a sound source than its direction, and the mechanisms underlying distance perception are still being investigated.
Looming sound perception:
The perception of approaching sounds (looming) has been studied more extensively in vision, but the auditory mechanisms for processing looming sounds are still relatively unexplored.
Body representation influence:
The impact of the body's representation on auditory perception, particularly in sound localization, is also an area requiring further investigation.
Ecological validity of virtual environments:
The extent to which virtual environments can accurately simulate real-world auditory experiences needs more study, especially for research on aging populations.
Sound and plant responses:
While some studies show that sound can affect plant growth and development, the underlying mechanisms of sound perception in plants are still being explored.
In essence, while our understanding of the auditory system's basic functions is relatively advanced, the complexities of how we interpret and interact with the rich tapestry of sounds in our environment are still being unraveled.
extermination
Anche non metterla giù troppo dura.
È noto e risaputo che ognuno di noi elabora, per certi versi automaticamente, un giudizio di un determinato evento sonoro ( live o riprodotto) rispetto alle sue attesa confrontando quella determinata esperienza con un quadro di riferimento interiore ( dato da precedenti esperienze-memorie) che, sempre per così dire, rappresenta il “giusto” ( per lui). Certamente il processo psicologico effettivo è più complesso, basti anche solo considerare l’interazione di fattori estranei come, per esempio, lo stato emotivo, stimoli e sollecitazioni sensoriali non acustiche, etc etc ma quello che resta fondamentale, è l’esistenza di un quadro di riferimento e che questo quadro non sia strettamente individuale ( chiaramente con tutti i distinguo caso X caso). È noto e risaputo che coloro che hanno effettuato un percorso cognitivo-esperenziale con intersezioni comuni (cultura-esperienza acquisita simile) hanno un quadro di riferimento simile.
8 ore fa, Franzbossio ha scritto:
La mia impressione è che tu li abbia considerati tali, tutte uguali visto che hai scritto che non esistono mezze anecoiche.
Non solo la tua, quando uno scrive è o non è, non ha chiaro di cosa parla.
8 ore fa, Oscar ha scritto:
Aririleggi attentamente... Non mi dare contro per partito preso. Rileggi, pensa e riformula la domanda.
Buongiorno, lungi da me darti contro per partito preso.
Ho cercato di correggere una tua affermazione errata.
Un utente, Grisulea, ti ha scritto che le anecoiche hanno prestazioni diverse, tu hai risposto con due frasi sbagliate, la prima con assolutamente no, la seconda con dipende dalle dimensioni.
Entrambe non sono corrette visto che tra varie anecoiche si può trattare la frequenza minima sia a parità di dimensioni, sia quando è piu grande, sia quando ha dimensioni piu contenute.
extermination
Ad esempio, prendiamo un attributo percettivo connesso ad una esperienza di ascolto globale che per semplificare è quello che corrisponde alla seguente espressione: quando mi trovo seduto in quinta fila centrale, i violini mi appaiono più chiari, mentre quando mi trovo seduto nelle ultime file mi appaiono più confusi. Questo giudizio conferma l’esistenza di una “scala psicologica” di chiarezza percepita in base alla quale l’ascoltatore è in grado di ordinare una qualità che va da confuso a chiaro.
@Franzbossio puoi dirlo.
 Comunque istruttivo entrare in un‘ anecoica.. equivale un po‘ ad entrare in uno spazio sconosciuto buio al 100%… spazi di deprivazione sensoriale.
Noi umani non siamo nati e attrezzati per tali esperienze.
Comunque al di là di tutto, la percezione acustica degli spazi è un fattore importante della progettazione architettonica.. noi umani riconosciamo gli ambienti anche solo dal timbro irriconoscibile di ciascun ambiente.
provate a bendarti gli occhi e farvi accompagnare ( senza sbattere… ) da un famigliare attraverso la vostra casa.. ogni spazio ha una sua timbratura precisa..
un‘ esperienza altamente istruttiva.
 Comunque istruttivo entrare in un‘ anecoica.. equivale un po‘ ad entrare in uno spazio sconosciuto buio al 100%… :-)
Hai ragione, un altro mondo a parte.
extermination
Ma è sufficiente entrare in una stanza in cui, il proprietario, ha imbrattato tutte le pareti con un semplice piramidale di 5 centimetri di spessore assorbendo fortemente  le medie e alte frequenze, per vivere una sensazione diversa dalla realtà di tutti i giorni dunque che può andare dalla strana sensazione non gradevole alla stranissima sensazione sgradevole e fastidiosa
Siete andati un pochetto fuori dall'argomento,torniamo dentro e ditemi se secondo il vostro parere e dopo 42 pagine di accesa discussione , un impianto riproducendo una registrazione, ce la fa' ad approssimare un pianoforte ?
extermination
Tenendo sempre in debito conto che la realtà fisica “non esiste” senza la realtà percepita e di conseguenza con tutto ciò di soggettivo che ne consegue.
ilmisuratore
Si
Conservo un paio di files che tanto tempo fa mi avevi inviato...ad alta dinamica :classic_sleep:
Un impianto può e deve approssimare ciò che sente ed elabora il tecnico al master nel suo studio, il resto non può esser dato
