Maurjmusic Inviato 3 Aprile Inviato 3 Aprile Diffusori di recente importazione in Italia Sembrano interessanti e competitivi … qualcuno li ha ascoltati? Grazie. LALS MOD CLASSICAL 15 EX-II Tweeter/Midrange: 50mm Titanium Compression Driver with 46cm Wooden horn BASS: 15 " Paper Cone Woofer Sensitivity: 98dB / W(1m) Impedance: 8Ω Frequency Response: 30 Hz~25 kHz Crossover Frequency:800 Hz Maximum Recommended Amplifier Power: 500W Horn and Cabinet Material: Russian Birch Plywood Finishing: Walnut Wood Veneer Treble Attenuator Dimensions:550(w) x 1225(h) x 500(d) mm Net Weight: 65 kg / each Country of Origin: Taiwan https://lals-audio.eu Lals Classical 12 SE II Tweeter/Midrange: 44mm Titanium Compression Driverwith 37cm Wooden horn BASS: 12 " Paper Cone Woofer Sensitivity: 96dB / W(1m) Impedance: 8Ω Frequency Response: 35 Hz~20 kHz Crossover Frequency:1200 Hz Maximum Recommended Amplifier Power: 500W Horn and Cabinet Material: Russian Birch Plywood Finishing: Walnut Wood Veneer, Ebony Wood Veneer Treble Attenuator Dimensions:450(w) x 1085(h) x 390(d) mm Net Weight: 46 kg / each Country of Origin: Taiwan
spersanti276 Inviato 3 Aprile Inviato 3 Aprile 2 ore fa, Maurjmusic ha scritto: Diffusori di recente importazione in Italia Sembrano interessanti e competitivi … qualcuno li ha ascoltati? Grazie. LALS MOD CLASSICAL 15 EX-II Tweeter/Midrange: 50mm Titanium Compression Driver with 46cm Wooden horn BASS: 15 " Paper Cone Woofer Sensitivity: 98dB / W(1m) Impedance: 8Ω Frequency Response: 30 Hz~25 kHz Crossover Frequency:800 Hz Maximum Recommended Amplifier Power: 500W Horn and Cabinet Material: Russian Birch Plywood Finishing: Walnut Wood Veneer Treble Attenuator Dimensions:550(w) x 1225(h) x 500(d) mm Net Weight: 65 kg / each Country of Origin: Taiwan https://lals-audio.eu Lals Classical 12 SE II Tweeter/Midrange: 44mm Titanium Compression Driverwith 37cm Wooden horn BASS: 12 " Paper Cone Woofer Sensitivity: 96dB / W(1m) Impedance: 8Ω Frequency Response: 35 Hz~20 kHz Crossover Frequency:1200 Hz Maximum Recommended Amplifier Power: 500W Horn and Cabinet Material: Russian Birch Plywood Finishing: Walnut Wood Veneer, Ebony Wood Veneer Treble Attenuator Dimensions:450(w) x 1085(h) x 390(d) mm Net Weight: 46 kg / each Country of Origin: Taiwan Le seconde (Lals Classical 12 SE II) mi ispirano di più per il punto di crossover più alto (generalmente meno critico sulle voci). Se fossero ben costruite... Mi ricordano molto le Opera Audio Consonance M12 Barque dei primi anni 2000. Certo è roba che costa. https://www.soundstagenetwork.com/revequip/opera_m12.htm
Discopersempre2 Inviato 3 Aprile Inviato 3 Aprile @spersanti276 Le Opera, dalla foto, mi sembrano meglio rifinite in generale🤔.
Discopersempre2 Inviato 3 Aprile Inviato 3 Aprile 2 minuti fa, fabbe ha scritto: @Turandot non è che queste facciano arrapare.... JBL?🤔.
Questo è un messaggio popolare. eduardo Inviato 3 Aprile Questo è un messaggio popolare. Inviato 3 Aprile 23 minuti fa, fabbe ha scritto: @Turandot non è che queste facciano arrapare.... Una JBL fa sempre arrapare. A prescindere ! 3
Giannimorandi Inviato 3 Aprile Inviato 3 Aprile @eduardo soprattutto non fatta in Taiwan, per quella cifra
Giannimorandi Inviato 3 Aprile Inviato 3 Aprile 2 minuti fa, Giannimorandi ha scritto: @eduardo soprattutto non fatta in Taiwan, per quella cifra https://audiocostruzioni.com/prodotto/JBL-s4700-2/ Qualche cosa anche di usato
Sonnyblues Inviato 3 Aprile Inviato 3 Aprile 2 ore fa, fabbe ha scritto: non è che queste facciano arrapare.... urende bellissime le Opera invece
Maurjmusic Inviato 3 Aprile Autore Inviato 3 Aprile 40 minuti fa, Giannimorandi ha scritto: soprattutto non fatta in Taiwan, per quella cifra Certo ma a listino il prezzo delle JBL S4700 è il doppio rispetto alla “omologa” Lals Classicals 12 Se PS A Taiwan sono prodotte anche le elettroniche top Parasound della serie Halo.
Mighty Quinn Inviato 3 Aprile Inviato 3 Aprile 1 ora fa, Giannimorandi ha scritto: soprattutto non fatta in Taiwan, per quella cifra Cioè? Fatta in Taiwan è un bel vantaggio Se uno è interessato a qualità Se basta un nome blasone allora giustamente si paga Meno qualità Più costo Ma bel nome
alexis Inviato 3 Aprile Inviato 3 Aprile .. la ricetta formale comunque é sempre quella classica, puo piacere o meno, a me generalmente piace di piu delle solite torrette citofonate, la struttura basica tromba piú driver a compressione piu woofer é quella.. poco cambia. E per quanto riguarda il suono dipende da come é implementata, puó suonare eccezionalmente bene o male, dipende :-) ma di certo se ben fatto un sistema come questo apre le porte ai migliori ampli mai concepiti, i single ended a bassa potenza, ancora oggi a mio personale avviso non raggiunti da altri sistemi silicei. Di certo un woofer che sale fino a 800 non é proprio il massimo, ma anche qui dipende.. 1
sandinista Inviato 3 Aprile Inviato 3 Aprile 7 ore fa, Maurjmusic ha scritto: Diffusori di recente importazione in Italia Sembrano interessanti e competitivi … qualcuno li ha ascoltati? Grazie. LALS MOD CLASSICAL 15 EX-II Tweeter/Midrange: 50mm Titanium Compression Driver with 46cm Wooden horn BASS: 15 " Paper Cone Woofer Sensitivity: 98dB / W(1m) Impedance: 8Ω Frequency Response: 30 Hz~25 kHz Crossover Frequency:800 Hz Maximum Recommended Amplifier Power: 500W Horn and Cabinet Material: Russian Birch Plywood Finishing: Walnut Wood Veneer Treble Attenuator Dimensions:550(w) x 1225(h) x 500(d) mm Net Weight: 65 kg / each Country of Origin: Taiwan https://lals-audio.eu Lals Classical 12 SE II Tweeter/Midrange: 44mm Titanium Compression Driverwith 37cm Wooden horn BASS: 12 " Paper Cone Woofer Sensitivity: 96dB / W(1m) Impedance: 8Ω Frequency Response: 35 Hz~20 kHz Crossover Frequency:1200 Hz Maximum Recommended Amplifier Power: 500W Horn and Cabinet Material: Russian Birch Plywood Finishing: Walnut Wood Veneer, Ebony Wood Veneer Treble Attenuator Dimensions:450(w) x 1085(h) x 390(d) mm Net Weight: 46 kg / each Country of Origin: Taiwan competitive con una Panda.
