McIntosh Ma 2375
  • Amministratori
vignotra
Type: Vacuum Tube
75 Watts x 2-Channels
Unity Coupled Circuit Output Transformers
Power Guard Screen Grid Sensor®, Sentry Monitor™, Solid Cinch™ speaker binding posts
6 analog inputs
Subwoofer output
5-band analog equalizer
PURE TUBE ARTISTRY
This all-analog masterpiece combines a vacuum tube preamplifier with a vacuum tube power amplifier in a single, elegantly designed unit. In the power amplifier section, four KT88 output tubes and four 12AT7 driver tubes deliver 75 watts per channel of effortless, low-distortion power. You will experience a rich, full-bodied sound through virtually any speakers thanks to our Unity Coupled Circuit Output Transformers. The vacuum tube preamplifier portion is powered by two 12AX7A and two 12AT7 preamp tubes.
To protect the KT88 output vacuum tubes, our Power Guard Screen Grid Sensor® (SGS) technology continuously monitors the current and adjusts the input signal in real-time to maintain optimal performance and tube integrity. If the current becomes too high, Power Guard SGS® will dynamically attenuate the input signal to keep the vacuum tubes operating at safe levels. Combined with Sentry Monitor™ fuse-less short-circuit protection, the MA2375 is engineered for enduring reliability without compromise.
The MA2375 offers an array of analog inputs, including two balanced and three unbalanced connections, to connect music streamers with analog outputs, CD players, tuners, and D/A converters. Connecting a turntable is an easy task via the configurable phono input that can accommodate both Moving Coil and Moving Magnet cartridges. The phono stage includes adjustable Gain, Capacitance, Resistance Loading, and RIAA equalization for optimal vinyl playback. A subwoofer output enables the addition of a powered subwoofer to extend low-frequency performance.
  • Thanks 2
https://melius.club/topic/29602-mcintosh-ma-2375/#findComment-1775756
